plumes of smoke
  • mkcman17
    • Jul 2010
    • 8240
    plumes of smoke
    recently did some basic maintenance on a malnourished m20b25 and now have everything buttoned up. runs, drives, and sounds decent now, minus a giant cloud of greyish-whitish smoke that comes out the back under revs.
    what's been done as far as i recall in terms of motor:
    timing belt/tensioner
    water pump gasket
    various vacuum/breather hoses
    spark plugs
    replaced and cleaned the injectors
    valve adjustment hot to .012
    o2 sensor
    full coolant and oil flush
    cleaned icv/tb
    ran fuel cleaner through tank
    deleted a/c and hoses
    we're fearing a head/headgasket, but previous to the above work plus driveline component work the car did not smoke at all and both the coolant and oil showed no signs of either. because of the current situation, the car is running on water atm. advice?
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
  • Dj Buttchug
    • Jun 2010
    • 7685
    ive been searching for you mike. maybe the time has finally come to give the m20 the boot
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • mkcman17
      • Jul 2010
      • 8240
      thanks ryan, but this problem is for my buddy's car! nearly bought a '97 today for a smoking deal, but it sold wayyy too fast.
      • Dj Buttchug
        • Jun 2010
        • 7685
        oh well thats good. DAMNN you gotta snag them up fast. two sold down here already. for way to much money tho.
        Ig:ryno_pzk
          With only water in the cooling ssystem, the smoke color from a leaking head gasket is going to be darker than it would with anti-freeze in the cooling system. So my long distance diagnosis would be a head gasket failure.
          • mkcman17
            • Jul 2010
            • 8240
            But prior to the basic engine work we did, there was no blown hg. Why would there be one now?
            • davem
              • Jun 2010
              • 705
              Installation error?
              • mkcman17
                • Jul 2010
                • 8240
                Installation of what? All the work was external.
                  It could be just coincidence. Nothing you've done should cause this, except maybe the fuel system additive.
                  • PNWDan
                    • Feb 2011
                    • 1326
                    water pump gasket
                    spark plugs
                    o2 sensor
                    cleaned icv/tb
                    Sometimes having the oil too full can also cause this. As engine vacuum increases with RPM it can draw oil through the ventilation system and into the intake. Oil drawn through the intake will be a different color than when its slightly burning it while running because of the larger quantity burned. Just an idea..
                    1987 Alpinweiß 325is
                    Like the PNW E30 Local Crew Facebook page
                      The engine would have to be seriously overfilled with oil. We routinely overfill race engine by a quart and experience no smoke.
