More power
  • Suspence
    • Jul 2009
    • 943
    More power
    What are all the options for more power? Looking to keep my engine N/A, I have a list of things that I plan on doing but I want to know how to squeeze more power out of it.
    :nice:
  • lifeiskaos
    • 1709
    save your money until you can afford a full out NA engine build, or a turbo, or an engine swap.
    but if you really want to put a bunch of money into a stock m20, a mild cam, m50 injectors, a chip, and good flowing headers is about the best you can do.
    • Sagaris
      • Sep 2009
      • 2243
      ^Do you have any recommendations on headers?
      Just make sure you have all the maintenance, sensors, and vac. leaks sorted out. Too many people try to cover up hesitation and running problems with mods.
      • matt0300
        • 549
        Valve job, new cam, megasquirt(or chip) Miller afm if u go with chip. With megasquirt u can do a afm delete there's a video on YouTube of megasquirt on an m20 they got I think a gain of 22whp before afm delete
        • Sagaris
          • Sep 2009
          • 2243
          which was mostly due to tuning.
            External engine mods have very little affect on power. A blueprinted engine, high flow head, better cam free, flow exhaust, MAF, and a MegaSquirt will make a difference.
            • devon.818
              • Feb 2011
              • 2937
              miller MAF, and/or WAR chip
              intake and free up exhaust a bit
              you can get a cam
              you can do a turbo build
              get a 4.10 diff
              bigger injectors
              • TimR
                • Mar 2008
                • 549
                Ah, lets have some fun, 200 wet shot of nitrous and a couple spare M20's and hoods
                • matt0300
                  • 549
                  Yea its mostly tuning but that afm is super restricting and it's cheap power
                  • m20freak
                    • May 2011
                    • 6
                    How fast do you want to go!!... everything needs to work together, any one thing doesnt make a great deal of difference without other supporting parts to match and that goes fo reverything from the air filter all the way to the tailpipe, if your going to leave the internals standard you wont be dissapointed with a mild cam and some headers and a free flow exhaust, after that you will need to look at all mannor of internal mods to make things work.
                    sigpic245Hp at the wheels
                    7800 rpm M20 2.7 atmo
                    full build is here http//e21jps.webs.com
                    http://www.youtube.com/watch?v=oZ2SDsIjeZA
                    http://www.youtube.com/watch?v=kOdPbErYlho
                    • matt0300
                      • 549
                      M50 rods and crank will save u around 8 pounds if u are going to do a whole build plus those connecting rods are forged so good if u ever do plan to Turbo. If u megasquirt get a 288 cam with new rocker arms and valve springs with a higher spring rate and upgrade fuel lines and change ur rev limiter to 9000 haha
                        • 34835
                        All rods are forged...
                        • matt0300
                          • 549
                          I meant pistons haha, m20 pistons are cast right?
                            • 34835
                            factory pistons are cast, not just m20s.
                            • matt0300
                              • 549
                              Cool, I didn't know that.
