Ok so car is running rich, check for vac leaks but haven't smoke tested. I know I need to. Changed o2 sensor, don't know what it is. Temp sensor? Tps? Oh yea Its an 88 IX, it backfires when I speed up and let off the gas, and I'm getting 10mpg, not throwing any codes. Doesn't feel like its getting all power till around 4g's.
car running super rich
The first thing I'd do would be to check the rail fuel pressure, statically and while the car is being driven. If that is okay I'd check to make sure the injectors aren't leaking, replace the ECT and ignition wires, plugs, cap, and rotor. I'd also verify cam timing, adjust the valves, and replace the CPS. If the backfires still occur I'd swap in a different DME.The car makes it possible, but the driver makes it happen.
Originally posted by matt0300 View PostThe cap and rotor are brand new, double checked my timing marks and tried 2 other dmes. Haven't checheck fuel pressure, *warning noob question* how?The car makes it possible, but the driver makes it happen.
i would highly suggest checking the running temp of the car with a infared thermometer, because that was what was causing my rich issues. I replaced pretty much all the sensors, injectors, checked fuel pressure, vac leaks, you name it!
edit: Oh! and how are you calculating your gas mileage?? by ODO? mine started going bad and i didnt realize it, but it was counting 1 mile for every 10 or so miles.
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
Originally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - Toy
A back fire is more likely to be the result of the engine running lean than rich. It can also be caused by timing errors. If the engine is running lean, partial misfires can make it seem (from the exhaust smell) like it is running rich. A better clue that the engine is running rich is the condition of plugs.The car makes it possible, but the driver makes it happen.
well just for future reference my car wasn't actually running hot, it was running too cold. it was the cause of all my rich symptoms.
2002 325i - DD
