ok help make decision
  • Faviolosky
    • Nov 2008
    • 154
    sitting in my garage i have two heads that have had a valve job, new valve seals and a resurface
    one is the "885" and the "731"
    now i have been reading up and it seems that it doesn't matter which way you go you'll end up at 130-140 whp
    i plan on putting bigger injectors and a MarkD chip
    first question
    AAHHH WHICH ONE.
    and the second one
    whethr an m30 AFM will help acheive better airflow since its bigger and thus better performance along with bigger injectors.
    1
    731 with dual springs and i cam
    0.00%
    0
    885 stock
    100.00%
    1
    What engine?
      • 34844
      if the chip doesn't support the AFM and injectors, don't bother.
      actually, don't bother either way. I'd just get the chip. :)
      as far as the heads - if you have a B25 or '88 set bottom end, you have to use the 885 head. if you've got an eta bottom end, then you'll want to use the 731, but you can use either.
      • Faviolosky
        • Nov 2008
        • 154
        Well if i mentioned the 731 it be common sense that itas a stock eta bottom but yea that is whAt it is.
        About the afm i was asking just for giggles but if anyone's done please sY something. So the 731 you say But then you say either lol so which one
          • 34844
          what? I can't understand anything you just wrote
          • E30Gus
            • Jun 2008
            • 781
            Wow!
            • Faviolosky
              • Nov 2008
              • 154
              Well he told me to use the 731 but followed with "you can use either" which didnt give me a definitive answer on which heald i should use
              • Eecen
                • Jun 2010
                • 1235
