How the hell does this happen??
  • JTapper
    • Sep 2009
    • 847
    Have about 20 miles on this head swap. This head sat on my shelf all winter, untouched. I had just done the valve adjustment a few months before putting it on this motor after blowing a hole into the old head.
    All the sudden while cruising at around 2.5k RPM, loud ticking commenced, this is the result:
    What the hell?
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
  • Brandon12V
    • 1318
    it happens. Were they new or the original?
    Originally posted by Ryan...
    It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
    • DTM190
      • Nov 2008
      • 1107
      nasty! subd for curiosity
      Originally posted by der affe
      first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
      if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
        The usual cause of that is improper alignment of the rocker shafts and the rocker shaft lock key not being present.
        • Eecen
          • Jun 2010
          • 1235
          Is there coolant in your head, on top of the broken/unseated rocker clamps, or is that just the camera?
          • JTapper
            • Sep 2009
            • 847
            Yes, and no. Was the key present? Yes. Had someone done some custom modifications to the valve cover? Yes.
            The "pegs" in the valve cover had been ground down, at least 1/4". I purchased it used, and sent it off for blasting and coating. Never realized it had been modified.
            The key was there, but had come lose, allowing the rocker shaft to turn, letting all the clips loose.
            No damage, clocked the shaft back where it belonged, installed the lclips, and adjusted the valves again.
            all is right in the world.
            It's just the camera. 20 miles on fresh 40w Valvoline VR1 oil plus LED flash on camera phone = coolant look.
            • JTapper
              • Sep 2009
              • 847
              Oh, and it sounded like this:
              Yes, that is steam. I recently blew the head and have a little coolant left in the oil. Plan on changing it again in about 50 miles.
              • reelizmpro
                • 9559
                Never seen that happen before. Maybe they weren't all the way down or got nudged when you adjusted the valves.
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • JTapper
                  • Sep 2009
                  • 847
                  No, I'd installed a new (to me) valve cover that had been modified so it no longer held the rocker shaft key in place.
                  • reelizmpro
                    • 9559
                    Any reason why they were ground down?
                    88 M3 - LACHSSILBER
                      I've seen the key left out before with that result (and worse), but I've never heard of anyone modding the valve cover like that. I can't imagine why someone would do that.
                      • JTapper
                        • Sep 2009
                        • 847
                        I don't know why the hell someone ground them off, but it was just plain stupid. After having that cover blasted and coated, I'm going to have a shop gob some aluminum on there and machine it smooth again. It'll be cheaper than having another cover blasted and powder coated again.
                        Looks like I'll be running an ugly one for a few weeks...
                        • CHIF8008
                          • 3447
                          dang that sucks man
                          -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                          -The Beauty in the Tragedy-
                          MECHANIC SMASH!!- (you all know you do it)
                          Got Drop?? ;-)
                          But of course
                          E30s are know to be notoriously really really really ridiculously good looking
