"E" to "I" head
  • scrambles30
    • May 2011
    • 43
    "E" to "I" head
    Ok so I have a 4 door 86 325e I recently traded my 89 325i vert for it and I miss the power difference I drift it and kinda need a litttle more so I wanted to know everything I would need to put an I head on my e block and how difficult it would be
  • Van Westervelt
    • 9365
    It will be a gutless turd if you simply do that. It drops the compression ratio down significantly. Only worth while if you are going to simultaneously boost it.
    If you had a 1988 325(e), then its plug and play for a few more ponies.
    Its been covered many other times too. Search for m20 stroker.
    • Killacortes
      • 1937
      theres a shit ton of threads on this topic brah
      r3v does not fuck around. First you get banned, then they shoot you
      • blindwOw
        • 124
        '87 Zinno 325e
        • ZekeTheSneak
          • 1562
          Put the i management on your e motor. Works. Trust me. May explode after 5 grand though. The car we have running like that may be an es so the head can handle higher r3vs.
          • kingston
            • Jun 2010
            • 2669
            Correct me if I'm wrong (and I may well be), but I don't believe the 's' designation has anything to do with the motor. I believe the es is essentially a suspension/chassis package... I think the head on your can (a 325es) is the exact same head as the same year 325e.
            Talk amongst yourselves...
            Originally posted by LJ851
            kingston is the play by play announcer for this thread.
            ‘Tis by the grace of God that my cars run!
            Originally posted by unloadedak
            #teamross
            Siobhan's Build Thread - UPDATED!
