ok R3V pop quiz.
  • samurai pizza cats
    • 457
    ok R3V pop quiz.
    lower radiator hose started leaking, changed it out and filled it up with coolant. started the car and all was well. then i test drove it for like 10 min and the low coolant light came on. so i looked and no signs of a leak anywhere and the coolant reservoir is still full and car is not overheating. wtf?!
    keepin it real since 1990
  • riceh8r
    • Dec 2010
    • 133
    faulty tank sensor...maybe.
    • LJ851
      • 7919
      bad coolant level sensor. You disturbed it by removing the coolant and now it is bitchy .
      Lorin
      The M30 is God's engine.
        • 457
        any way to test it? O.o
        • LJ851
          • 7919
          Its just a float with a switch on it. Not sure if it works out of the fluid but i think it does. It should be open when the floats up and closed(electrically) when down . They are prone to failure, if yours is old i would replace it. Also,if you unplug it the light should go out.
          Lorin
            • 457
            cool, will do. hopefully that fixes the problem. thanks for the heads up
