ebay chip
  • herbie
    • Jan 2011
    • 206
    ebay chip
    Ok guys, i've searched and found nothing really helpful. So here I am creating a new thread. I have a 1990 325is, so it has the M20B25. It also has the 525 Bosch DME. I bought an ebay chip for some power gains. When i installed it, it gave me noticeable power and the rev limiter was raised to almost 7000 RPM. Everything was great, the car drove great. but the problem was, the check engine light came on. Fearing that it might hurt the car in anyway, I installed back the stock chip and the light was gone, so was the extra power, responsiveness and the rev limit was back to 6500. My question is, would running the ebay chip hurt the car in any way? i know i know i get what i pay for, so spare me the lecture. All I want to know is if it is still safe to use until i get enough money to buy the proper chip? thanks in advance.
    That rather depends on what fault is triggering the light. If your TPS is good, a stomp test will pull up the fault codes.
    Are you sure this chip was meant to be intalled in a 525 DME?
    • herbie
      • Jan 2011
      • 206
      See, that's the thing, i am not sure if the product i got is compatible with the 525 DME.
      here is the info
      High Performance Chip BMW E30 320i 325i E34 520i 525i
      Item number:140530957048
      • devon.818
        • Feb 2011
        • 2937
        oh oh oh pick me!
        ask the ebay seller.
        • herbie
          • Jan 2011
          • 206
          i just asked the seller, waiting for his response, if not, it's 20 dollars down the drain. Do you guys think the Miller induction kit is worth it? would it really make my car more lively?
          • devon.818
            • Feb 2011
            • 2937
            miller MAF and do your own CAI.
            i have the miller MAF and dont really think its all that...
            • herbie
              • Jan 2011
              • 206
              hi devon, you dont think miller maf kit and chip wont make a big difference? so, in your opinion, it is not worth it?
              • Brandon12V
                • 1318
                if you want set it and forget it, go with markD, turner/Conforti, dinan, etc. if you want to tune your set up specific as you add more parts down the road go with miller. theres probably over 100 chip threads, in the archives, on the m20 alone.
                Originally posted by Ryan...
                It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                  • 34847
                  it's probably getting a CEL because the chip is a rip off of another brand (like Mark D or JimC).
                  They just read the other guy's chip and burn it onto a 50 cent blank, then sell it to you for $100 or whatever. Now do you feel ripped off?
                  • herbie
                    • Jan 2011
                    • 206
                    thanks for all your help. chip is out the car, saving up for a legit one, but lusting for the miller induction kit.
                    again, thank you guys
                      • 37834
                      Have you ever copied a chip before? Do you know anything about it?
                      Copying a chip won't magically add a check engine light.
                      The check engine light was most likely on because the ad says the chip is for the 173.
                      Grover Beach, California
                      BimmerHeads.com
                        • 37834
                        Honestly you can just buy a 173 ECU and put it in along with the chip. I would run it if it were mine. You can pick up a 173 ECU for about $50 shipped. If you decide you don't want the chip anymore PM me and I'll buy it.
                        BimmerHeads.com
                          • 34847
                          it can if they don't flash it properly, don't do the checksum properly, etc. etc.
                          speaking from my own similar experiences I've seen all sorts of strange issues from a flash that didn't go quite right.
                          plus you're still directly supporting theft.
                            • 37834
                            Guess I don't know much, only used a chip burner and software first hand.
                            Yes, you know me. Total criminal. STFU dude.
                            BimmerHeads.com
                              • 34847
                              WTH?
                              if you want to burn chips in your bedroom, I don't care. but if you're copying a JC or MarkD chip or whatever, you are stealing. There's no way around that. It's much worse if you're also selling them to people.
