What size piston rings for a Turbo'd M20 Motor
  • kreaglewon
    • Jul 2010
    • 27
    Anyone know what is the best ring size,choice, and brand ?
    • 37832
    Stock.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • 10-66kruk
      • Nov 2009
      • 434
      Well I'm pretty sure there is an exact size based off the size of the bore. It's not like one of the things where you put bigger rings in cause you are doing a turbo. If you bored it out then you could go bigger and stuff like that. Though I do know that total seal is a good choice for rings.
      sigpic-Thanks warren
      • Ryann
        • 3350
        This. Ring "size" is based upon bore diameter so that when installed they have the correct end gap. Goetze is good stuff.
        • Myster-E
          Performance
          • 552
          Hastings makes great rings for m20s
          1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
          Visit www.BimmerHeads.com for all of your 12 valve needs!
          • artoo93
            • 909
            Whatever is needed after boring and/or honing has been completed. After block has been prepped then end gap it to find the correct size. Same idea for the crank as well.
            Some people just need a sympathetic pat...
            on the head...
            WITH A HAMMER!!!
              • 37832
              There's really no reason the block should need any boring or honing unless you're doing bigger pistons.
              Grover Beach, CA
              www.BimmerHeads.com
