Recently got an 85 325e and it had it's issues like all e30's do but the one I'm still working on is this stupid missfire. It idles fine and if you just get on it super smooth it drives fine but as soon as you go to power anything, it breaks up and it feels like it dies on a cylinder. I changed the cap, wires, and plugs and still nothing. It runs the hell of a lot better but still does it's missfire under load. My next step is doing a valve adjustment(probably due for one anyways) and seeing if that helps. Any thoughts?
Breakup under power?
Recently got an 85 325e and it had it's issues like all e30's do but the one I'm still working on is this stupid missfire. It idles fine and if you just get on it super smooth it drives fine but as soon as you go to power anything, it breaks up and it feels like it dies on a cylinder. I changed the cap, wires, and plugs and still nothing. It runs the hell of a lot better but still does it's missfire under load. My next step is doing a valve adjustment(probably due for one anyways) and seeing if that helps. Any thoughts?Comment
Well atleast I'm not alone in this boat, and as far as the valve cover, already did an adjustment an oil change too it the other day and it looked to be in good shape. Bo broken rockers, or bad keepers, and it was relatively clean(as clean as I'd expect a 26 year old valve train to be). But I wish you luck with yours and I'll keep you posted on any changes.Comment
