e motor with super e harness injectors?
  • 324tdi
    • Jun 2010
    • 274
    I want to install an e motor with super e harness and brain...I would guess that I need to use the super e injectors on the e manifold, what else? I search, could not find any info...
    The reason for this is I want updated motronics with flywheel sensors, does that make any sense?
    Thanks
    Al
  • reelizmpro
    • 9554
    Why would you want that? Either go one way or the other.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
      Not a good idea. The ETA and SETA motors have different characteristics and thus require an engine management system tuned to those characteristics.
      • hotballs
        • 1155
        I will sell you all my super eta intake manifold, injectors and what not if you want to go to all that work to gain 6 hp or whatever it is.
        • e30trooper
          • 11576
          a chipped eta will out power a seta...
            • 37833
            Yeah, definitely NOT worth the trouble.
            Grover Beach, California
            BimmerHeads.com
            • blueapplesoda
              • Dec 2005
              • 1904
              Well, Al, if you still want to do this, search google for the eta specific motronic 1.1/1.3 conversion guide. You will find a list with all the parts to run updated electronics on your eta.
              In my opinion, go to the yard and steal everything off a 325i (cylinder head and all related equipment for motronic 1.3) and build yourself a fun car.
                • 37833
                Exactly what I would do. Do the full i top end and electronics and you'll have something with decent power that can actually rev!
                BimmerHeads.com
                • 324tdi
                  • Jun 2010
                  • 274
                  Hey Guys
                  Thanks for the info, here is why I am wondering about this, have a 24 hour race coming up, have 3 eta motors do not want to burn up one of my SPEC e30 i motors running chumpcar....have all the parts from the Super E we ran in the SCCA 13 hour at VIR last year...so I have this stuff laying around, what I do not have is a trans with the sensor holes for the e...or the sensor's on the single mass flywheel.
                  Thanks
                  Al Taylor
                    Seems to me you have three possible solutions. One would be to get an ETA compatible transmission, another would be to make a budget stroker (M20B25 AFM, FPR, intake, injectors, head, harness, and DME) and the last would be to use a SuperETA harness & DME. An ETA engine isn't going to run right with the SuperETA management system, but it will run better than if you use the harness and DME from an M20B25. Of those three I'd go for the "budget stroker".
