Fuel pressure regulator vacuum hose
  • jaydeep
    • Jun 2011
    • 208
    In my 88 325is Fuel pressure regulator vacuum hose is broken. Would that cause anyting? Can I get FPR vacuum hose from Autozone? What size is that?
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
    • 37829
    Yes it would cause a vacuum leak and take away vacuum from the FPR. Can't remember the size but yes any auto parts store should have this in bulk. Just pull off your hose and bring it in to compare size.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • matt0300
      • 549
      Just bring in the old one and have them cut it to the right length
      • e30lov
        • Jul 2008
        • 1597
        When my FPR vacuum hose went bad it would cause the FPR to leak fuel. Wasn't very cool
        `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
        • whodwho
          • Jun 2008
          • 1547
          That is just a common failure of a FPR it wasn't from the bad vacuum hose.
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • e30lov
            • Jul 2008
            • 1597
            But I replaced the hose and now it doesn't leak anymore.
            • whodwho
              • Jun 2008
              • 1547
              Where did it leak, out of the vacuum nipple? If so it will suck the gas into the manifold and run rich.
              • jaydeep
                • Jun 2011
                • 208
                I put clear hose and noticed fuel was coming form FPR and sucking through vacuum and intake manifold. Is that normal or my FPR is gone bad?
                • TrippinBimmer
                  • Feb 2011
                  • 182
                  Goes to the hoses it's going bad.
                  • whodwho
                    • Jun 2008
                    • 1547
                    Any fuel coming out of the vacuum nipple means there is a hole in the diaphragm and it is bad.
                    • acolella76
                      • 2950
                      so the hose should be dry, correct? I thought I read somewhere that the hose should be wet on the inside (lol) but i didn't think that was right...
                      OP, go to autoparts store and just buy a ton of different sizes of vacuum hose. I bought I think a meter of every size vacuum hose and its safe to say I no longer have any leaks.
                      -Alex
