Retapping oil pan question
  • Dsun
    • Jul 2011
    • 371
    Ok so I guess PO took my car to a mechanic that used a impact wrench to tighten the bolt to the oil pan. I noticed it drops oil from the bolt and when i removed it for oil change i noticed half the treads are shot.
    I know that the M12x1.75 wont work, but will a M14 with a bolt the same size work? Or is that too big?
    I would hate to get a new oil pan, but that would be worst case scenario.
    Any tips/suggestion? Thanks.
    Had a smooth purchase transaction with me?
    Please share your feedback
  • Dj Buttchug
    • Jun 2010
    • 7677
    the easiest way to do this is to just drill and tap the next size up.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • jaywood
      • Jul 2010
      • 4528
      This. Make sure you get a bit big enough to get rid of all of the previous threads. You don't want to "cross thread" when making new threads
        I prefer to use a TimeSert thread repair for this. The job can be done w/o removing the pan.
        • Dsun
          • Jul 2011
          • 371
          retap it is, any suggestions on retapping tools?
          • PNWDan
            • Feb 2011
            • 1326
            ^do this ^
            It makes it stronger as well. You should be able to get the stuff at any specialty fastener store or online.
            1987 Alpinweiß 325is
            Like the PNW E30 Local Crew Facebook page
            • Dsun
              • Jul 2011
              • 371
              Anyone know if its safe to drive short distance (less than 2 miles) with half of the oil pan's threads stripped? Obviously it wont be hard driving, less than 30 mph on the local roads and will be going light on throttle.
              THe bolt is not loose but there is a slow leak...maybe 1 drip a hour or so. Im paranoid that the oil pressure while driving will cause the bolt to shoot out. ANd i am currently taking up a parking space at my friends place.
              • devon.818
                • Feb 2011
                • 2937
                check the oil before hand, then roll out.
                as long as you keep topping it off you could prolly drive it for a while.
                honestly, i wouldn't fret it
                • PNWDan
                  • Feb 2011
                  • 1326
                  The pan isnt pressurized, the oiling system is. it will just drip normally. Most likely it will drip a bit more when hot but just drive a bit and re check.
                  • blefevre
                    • Dec 2008
                    • 4287
                    Mine got striped like crazy once. I put some blue loctite on what was left of the threads, let it sit, then drove about 15-20 miles to a shop to have it heli-coiled. It has held up perfect after that. Again, the pan isn't pressurized so your biggest concern is if the bolt will vibrate out.
                    - E30, DSM, Golf R, Mazda 3 Skyactiv
                    • PNWDan
                      • Feb 2011
                      • 1326
                      Being a machinist by trade I tend to think everthing that is threaded aluminum should have some sort of steel insert. Especially oil pans and such that are from a crap grade of soft aluminum. it would make life so much easier...
                      • gillette
                        • Jun 2011
                        • 55
                        I highly recommend heli-coils. I retapped and did the inserts on almost all the bolts on my oil pan on my cherokee and the head on my brothers 240sx and they hold real tight with no leaks. Takes a lot of patience so take your time!
