whats the difference?
  • samurai pizza cats
    • 457
    sorry if this Q is obvious, but im changing the head gasket on my 87 325i and i was wondering what was the difference between a 1.75mm head gasket and a 2.05 head gasket? just don't want to get the wrong gasket and then have to go back and get a different one. thanks!
    keepin it real since 1990
  • Cabriolet
    • 9620
    if you have to mill alot off the head you use the thicker one.
    Much wow
    I hate 4 doors
      • 457
      cool man, thanks!
      • matt0300
        • 549
        Just use OEM one, if u had head resurfaced it will lower ur compression.
          Surfacing the head increases compression ratio, but that affect is minor compared to the change in camshaft timing. A thicker head gasket compensates for th loss of material from the head and restores both the compression ratio and cam timing.
          • digger
            • Nov 2005
            • 5994
            i think it is pretty hard to find the thinner gaskets these days.
              • 37828
              Run the OEM thickness.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
