M20 crank sensor: 2 per vehicle?
    The fap99 website says that my 1988 325i gets 2 crank position sensors. Does that make sense?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
    If you have a CPS on the front pulley, there is only one. If you have sensors in the trans bellhousing there are two ( speed and reference)
    Lorin
    The M30 is God's engine.
      Fap99 is bueno. 325e had 2 CPS in the bellhousing, 325i had 1 on the front of the engine. If you have any worries that you will get the wrong one, just call Tim (the contact # on the site), he is an E30 guy and will make sure you get the right one.
        Your car only has a single CPS mounted on the front of the engine. Only ETA cars (through 8/87) had two timing sensors mounted in the transmission bell housing.
          Thanks to all. Confirmed part # on realoem.com
          BMA parts was $40
          Fap99 was $56
          so it pays to shop around.
          -Dr. Paul Forrester
            BMA parts was $40
            Fap99 was $56
            check blunt too
            1989 cirrisblau-metallic 325i
