Bad knock from worn rod bearing?
  • tommye
    • Jun 2011
    • 11
    Did a engine swap in my e30, but the new engine got a bad knock.
    Sounds like REALLY bad rocker arm knock.
    The noise sounded like it came from cyl 3 or 4.
    Took the engine apart, and all top half rod bearings are worn out.
    And the top half on cyl 4 has lost it shape somehow, its bent in.
    But my question, is the bearings the cause of the knocking, because it only sounded like only one cylinder got a knock, but all bearings are worn out?
    Took some pictures:
    The two last ones show the "deformed" half ontop of another.
    btw the main bearings look like new.
  • matt0300
    • 549
    It could be, did ur oil pressure light come on at all? Cause if ur main bearings are bad ur oil pressure would be fluctuating all the time. Main bearings cause knocking too.
    • sweet6e30
      • Feb 2011
      • 531
      i smell rebuild
      my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
        This engine has experienced a lack of oil pressure. You need to mike the crank and see if it is still within spec.
        • Cinnabar325is
          • 1064
          Before undoing the rod caps, you should have taken your hand and tried to rock each cap back and forth to see if there was any play in it. That would have told you which rods were knocking.
          Even if only one or two rods were currently knocking, it looks as though all your bearings were wearing out and eventually, you would have had more rods knocking.
          I'd highly recommend checking to see if the rod bearing journals and the rod big ends are within spec! You don't want to find out they aren't the hard way.
          '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
          • sweet6e30
            • Feb 2011
            • 531
            x2^
            • tommye
              • Jun 2011
              • 11
              I did try to rock them, didnt feel any play or maybe a tiny play on cyl 4.
              The oil pressure light came of right away after start.
              But the engine has been run with a blown headgasket, may that be the cause?
              The main bearings look fine, just like new.
              • ForcedFirebird
                • Feb 2007
                • 8300
                If the engine was run with water/coolant in the oil, it will wipe out the bearings. I have done more than one repair where the customer was advised about possible bearing failure when they drove the car with water/coolant in the oil. Last 2 times I replaced the head at their request spite the warning, one had knock after, the other had no oil pressure. Water is not a bearing lubricant.
                john@m20guru.com
                Links:
                • tommye
                  • Jun 2011
                  • 11
                  Measured the crank today, it's pretty close to 45mm all the way around.
                  So the crank is probably ok. Dont have any scratches either.
                  So the solution for my knock is most likely some new rod bearings?
                  Maybe open the oil pump to check for wear and tear?
                  • LJ851
                    • 7919
                    ^ your mic is not accurate enough. You need one that reads in .0001 inches or metric equivalent. Measure each journal at 4 positions: left side of journal 12o clock to 6o clock, and then 3o clock to 9o clock. do the same on the right side of the journal. You want to find out if the journal is oval or tapered. I wouldn't run it if it has more than .0003- .0004 inches of either.
                    Lorin
                    The M30 is God's engine.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Yeah that 1/50th mm mic is only accurate to about .0008".
                      john@m20guru.com
                      Links:
                      • riceh8r
                        • Dec 2010
                        • 133
                        caliper is going to give a more accurate reading, and you can roll it around the journal. my $.02.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          What? Even the Mitutoyo digital calipers I use aren't as accurate as mics. Calipers are lucky to be within .0005" never-mind less.
                          john@m20guru.com
                          Links:
                          • LJ851
                            • 7919
                            Haha , thats a good one. All these years i've spent building high performance engines and i've never heard that one before.
                            Lorin
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              The CNC machine I program will hold .0002" for hundreds of parts, fully aware of being able to measure parts. My surface grinder will hold 50 millionths, measure that with your calipers.
                              john@m20guru.com
                              Links:
