I am experiencing a sudden power loss in my 1984 325e (as in acceleration/engine power). The car loses acceleration power and than kicks rite back on with full power...It almost feels as if its starving for fuel or air...Today i tested to see if I was getting power to the fuel pump and fuel pump relay both test were ok. I listened to see if i could hear the fuel pump turn on but i heard nothing...Fuel pump replay was fine as well as fuse's. I am thinking its a bad afm or maybe the fuel pump regulator? Wondering if you have any opinions or other test i should run before trying to find a used AFM to buy on here. Any help on this matter is greatly appreciated.
I also have recently replaced distributor cap, rotor, ignition wires, spark plugs and fuel filter.
Thank you for your time
