I am taking down the m20 from my two ixs and I plan to rebuild it with the best combinations of parts from the two and a more agressive cam and i was wondering if this is a complete list of things I would need to create a leak free motor(or at least less leaks)
This is going to be my first tear down so I hope between the search tool, you guys, and Bentley that i will be able to do this so thanks in advance
Plastigauge
JB Weld
Permatex Anti-Seize Compound
Lubro-Moly Assembly Lube
Red Loctite
Curil-T Sealer
Loctite Black Silicone
Loctite 574 Case Sealant
new cam
head gasket set
intake manifold gasket
block gasket set
oil pan paper filter
Plastigauge
JB Weld
Red Loctite
Curil-T Sealer
new cam
head gasket set
block gasket set
