auxilary fan just staaays on
  • ROLLingKING
    • Apr 2011
    • 1169
    Ive got a 87 325is and just put the resistor on yesterday and for some reason this damn thing just stays on. I just want it working properly. I retraced my wiring, pulled off all my electrical tape and its all wired properly. I dont know what the problem is!
    Maybe ill just try the wires in different positions.
    This is what i had for reference... http://www.bimmerfest.com/forums/showthread.php?t=43317
    Does anyone actually KNOW what the green/black or all black or black/brown wires actually function are. If i know that maybe I can reposition the leads and get it working
    m20 is plenty. im simply a drifter.
    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
  • ROLLingKING
    • Apr 2011
    • 1169
    could it be the aux fan temp sensor that plugs into the radiator?
    im almost positive my wiring is correct
      That, a bad fan relay, or a bad A/C switch. If the fan is on with the ignition off, a relay becomes the prime suspect.
      • bmwm42
        • 6300
        Unplug the senor see if that turns it off
        Originally posted by bmwm42
        PNW vulture pm me for parts
        Strategic nw e30 command
        • ROLLingKING
          • Apr 2011
          • 1169
          so after some more research...i tried the fan with only 1(green/black) & 2(back) wires. The fan immediately cuts on when i turn the key to "on" position. When I press the ac button it stays on.. from what i read this is a way to test the low speed..
          Next i again left wire #1(green/black) plugged in. this must be the ground wire?? no?
          well i tested wire 1(green/black) with 3(black/brown) wire left plugged in, turned the key to "on" and it doesnt cut on right away. only once i hit the ac button..according to a write up doing wires 1&3 together should be high speed fan...soooo should high speed fan come on with a/c. I thought the low fan did that. should i switch wires 2 & 3 which are also the terminals theyre in. I am assuming the green/black is still the ground since that wire stays plugged in
          • ROLLingKING
            • Apr 2011
            • 1169
            and my bad the fan doesnt stay on while the cars off..it just stays on when the car is cold, wu=hile im on the highway i believe and when i turn the key to the "on" position
            • ROLLingKING
              • Apr 2011
              • 1169
              i just put in water wetter last week hahaha
              i dont want to spill my coolant everywhere.lol
              • ROLLingKING
                • Apr 2011
                • 1169
                a little more insight...
                i tried switching 2 & 3 the al black wire with the black/brown turned the key to "on" position and my fan was on TUUUURBO speed..or maybe thats just high speed. this is the first day with a resistor working so im not really sure what i should be hearing
                • ROLLingKING
                  • Apr 2011
                  • 1169
                  after more testing of wiring possibilities i did the green/black wire in terminal 3, brown/black in terminal 1 and all black wire in 2. turned key to on position and no fan. hit the a/c button and TURBOOO FAN. could feel the car shaking it was soo fast.
                  got the same results from switching the wires to all black-1, black/brown-2, green/black-3
                  now im trying the all black wire at 1, green/black at 2 and black/brown at 3...the fan came on as soon as i switched the car to the "on" position. Ill go drive it to see what happens when it warms up. otherwise im going to go back to what the other link said..... http://www.bimmerfest.com/forums/showthread.php?t=43317
                  • ROLLingKING
                    • Apr 2011
                    • 1169
                    basically im back to the "correct" wiring now with just the all black wire and green/black wire switched..time to go drivin!
                    • bmwm42
                      • 6300
                      you would just be unpluging the sensor not removing it from the radiator bro
                      • ROLLingKING
                        • Apr 2011
                        • 1169
                        well unpluging the sensor would stop the fan!
                        thats the power source right? cause unplugging the sensor turns it off..but i would expect it to
                          The sensor in the radiator is a pair of thermo switches. One trips at 91C and causes the fan to run at low speed and the other trips at 99C and causes the fan to run at high speed. If the fan turns off when you disconnect the sensor, it is bad.
                          • bmwm42
                            • 6300
                            fail the sensor only is suppose to work with it reaches a certian temps one for low speed one for high... your sensor is fucked
                            • ROLLingKING
                              • Apr 2011
                              • 1169
                              oooh so if i unplug the sensor and turn on the a/c the aux fan will turn on? my ac doesnt work since theres no belt on the compressor but it should have an effect on the fan.
                              im going to go try it now. and does it sounds like my sensor is fucked. oh well. at least im getting closer to my car not overheating!
