ICV Help
  • BrandonG
    • 232
    ICV Help
    so i got my e30 back on road today . installed a new battery and waterpump .. i drove it al day then took her to gas station and after filling when i left it shut off like a vacume leek occured so i opend hood and cranked it with icv unplugged and it fired but died.. so i figured icv failed in position for cold start .. i let it cool off and it started right up... wen i got home i unplugged the icv and the idle did not change at all .. does this meen it failed ??? i think it was going bad cuz it would often show symptoms of a bad icv .. wats best route of fixing this if im on a very tight budget as the waterpump new rad and battery killed me plus i just bought a jeep SMH
    DO WORK
    No change when you unplug the ICV could be be caused by a bad or sticky ICV, a bad TPS, intake leaks, a bad DME (or on an ETA car a bad Idle Control Module).
    • BrandonG
      • 232
      hmmm i hope dme didnt die ... it starts and runs fine ? i drove it home soo i think it was sticking icv because i could feel the icv vibrating like it could not move
      DO WORK
      • BrandonG
        • 232
        sprayed it down in carb cleaner and letting it air out tonite then im gunna put it all together tmoro .. prbly go to junkyard and get new intake boot and icv hose and icv
        DO WORK
