86 325e wont star got fuel and spark ???? any ideas
  • e30freak661
    • Feb 2011
    • 7
    so i bought an e30 from a guy with a blown motor i put a new motor in now first problem i ran into as soon as battery is plugged in even with the key out the windows work and everything like it has constant power ?? second if i turn the key to on possition abut 3 times then try to start it it will sound like it eants to then just keeps cranking any ideas would really help this is annoying i have plenty of spark and fuel havent checked pressure or bu thats next thanks
    Do check the rail fuel pressure. If off by a good bit the engine won't run, though it may fire with starting fluid. Also check for for intake leaks.
    • e30freak661
      • Feb 2011
      • 7
      so i got her started runs strong but another problem now is lets say i start the car starts u real low rpms then catch's up and idles fine but when you give it full throttle it just wants to choke and die out but i can rev it to the moon if i go slow ? some one help i checked for leaks nothing what now ? maf ? oh another thing the throttle controll unit under th throttle body if i plug it in or unplug it it doesnt change anyting could that be my problem ?
      i can get the car to rev right and run really smooth if i block of like 3/4 of the maf then everything is great till i move my hand ?
      • Wintel
        • Sep 2011
        • 2
        I'm having a similar problem with my car.
        • matt0300
          • 549
          Afm maybe. Did u check to see if ur spark pluges are fouled? Ur wot switch shouldn't be the problem.
          • e30freak661
            • Feb 2011
            • 7
            new plugs wires all sensors all new vacuum lines everythign still nothing ahhhhh
            • e30freak661
              • Feb 2011
              • 7
              wot?
              • matt0300
                • 549
                Ur wot switch just puts it in open loop. To test it just unplug ur o2 sensor and see if its still sluggish when u put ur foot down.
                • matt0300
                  • 549
                  Or closed loop sorry.
                  • e30freak661
                    • Feb 2011
                    • 7
                    yeah i unplugged that and made no diff the only thing that changed anything is if i block half the maf so it restricts the airflow i guess and then the car runs great so idk
                    • jaysee
                      • Sep 2011
                      • 82
                      my cars pretty much doing the same thing right now.. have you checked for vaccum leaks?
                      also there is a good write up on testing the afm @
