Coolant leak - dripping from a/c compressor?
  • saturnv7890
    • Jan 2011
    • 696
    Well I've got myself a pretty severe coolant leak.. my car heated up like a mutha****er on an otherwise decent first date with a girl that might be worth fixing my car for ;)
    So yeah, basically the temp climbed like crazy, and by the time I got back to my apartment it maxed out the dash temp gauge... I know you're gonna give me a hard time for driving it like that... but it only surpassed the useable range for about 2 minutes...
    Anyways, I filled it up with water and turned it on... had to wait for the thermostat to open up, then it started dripping from the bottom of the a/c compressor. Perhaps it's kinda dripping its way there? Has anyone had a similar issue? Where is my leak?
    thanks!
    My Transaction Feedback
    My "build" thread
    BUY MY CAR!!
  • Eecen
    • Jun 2010
    • 1235
    I'm thinking rear crank seal.
    • bmwguy325is
      • May 2011
      • 1263
      Well AC comprisors with coolant are rare. LOL JK
      I bet you smoke the water pump or the front on the head gasket. Never look for the leak at the bottom. This thing called gravity make things up high end up low. Its weird. ANd yes pulling over is WAY better than Well I think I can make it.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • bmwmech1
        • Jun 2010
        • 1075
        Yup, what you said... all of it, lol!
        Garey
          If the needle made it to the red, even for a very short time, the odds of damage to the head gasket are pretty high. That damage may be immediately evident or it may not show up for a little while. The most likely symptom will overheating from air being pumped into the cooling system. The next most likely symptom will be milkshake in the oil.
          Coolant dripping off the A/C compressor is probably from a hose failure or water pump failure.
          • saturnv7890
            • Jan 2011
            • 696
            thanks for the advice! I'll start looking
            My "build" thread
            BUY MY CAR!!
              • 37833
              This has to be a joke?!
              Grover Beach, California
              BimmerHeads.com
              • siazul
                • Jul 2010
                • 185
                If you have the early model water pump with a hose leading to the expansion tank Id look at where it connects to the pump and make sure its not leaking there, mine is very slowly and I get dripping coolant from the A/C compressor and bracket
