Alternator Swap OK?
  • AV325i
    • Jul 2008
    • 104
    Alternator Swap OK?
    I have an 89 325xi and a 90 325i parts car. The 89xi has a Valeo alternator that looks like original equipment. This car has flickering lights and the battery is not charging well (voltage regulator?). The 90 325i has a Bosch alternator (AL49X). It looks newer, like it was replaced. It is also smaller. Is it OK to swap these two? Any downside to the Bosch alternator? Thanks!
  • bmwguy325is
    • May 2011
    • 1263
    Go to a real parts house and buy this:http://bavauto.com/shop.asp
    I got mine at carquest cheaper than than bav auto. WOrld pac sells E30 stuff. You do not even have to pull the alt to change it.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • AV325i
      • Jul 2008
      • 104
      Thanks. I already took the alternator out, but it is good to know I don't need to for the future. I looked i[ my alternator on Bavarin Auto Parts and they list the Bosch AL49X for both the 89 325xi and 90 325i. Should have thought of that first! Still the Valeo looks like a higher quality part, so I think I will use the Bosch temporarily and get the voltage regulator for the Valeo
        • 37833
        Yes they interchange. And it's called a 325ix.
        Grover Beach, California
        BimmerHeads.com
