I broke a rocker arm at a recent track event and went through the whole replacement procedure without removing the head. I went to start it up for the first time and there was steam coming out of the exhaust, which I expected since I had to loosen the head bolts to slide the rocker arm shaft out. The problem was, it didn't go away after 10 minutes of running the car.
I had followed the proper tightening sequence of the head bolts (22 ft-lb, wait 15 min, turn 90 deg more) so I thought maybe the final 90 degrees would be enough to stop the leak. Sure enough, it wasn't. The car still steamed just as bad.
Any advice on what to check/do before pulling the head to replace the gasket?
What a frusterating project! Any advice/help is greatly appreciated!
Thanks!
Thanks!
