Freeze Plug Help, Cant Find The Leak!
Is it turning over? If it isn't turning over then changing the ecu won't do anything because bad ecu's still allow the starter motor to turn the engine over.
And if thats the case then it sounds like you shorted out your starter motor. Or something along those lines such as starter motor relays or fuses.
If the windows,head lights and blower motor dont work your unloader relay has gone bad. When you turn the car over the unloader relay cuts power to them to give more power to the starter.
This will also happen if the ignition wire is not hooked up correctly to the starter. Jump pin 15 iirc on the body harness to the chassis (ground) and see if you hear a clicking noise. If you do, their fine and the ignition wire isn't grounding properly to the starter.
