CA smog check
  • leone30
    • Jan 2009
    • 25
    CA smog check
    This is smog check result:
    rpm %co2 %o2 HC %CO NO
    max meas max meas max meas
    15 mph
    1860rpm 14.5 1.1 108 122 0.71 0.52 767 987 fail
    25 mph
    2000rpm 14.6 0.7 83 68 0.58 0.49 706 369 pass
    car 220000mi, gas used 91
    Any ideas why it failed?
    Thank you
  • e30trooper
    • 11576
    did you run the car hard b4 testing?
    • ethrtyiS
      • 8147
      run the car for like 45min to get it really hot, then drive straight there and get it tested.
      「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
      「my feedback thread」
      • noahp45
        • Jun 2011
        • 107
        Run a full tank of 91 and FI cleaner, Put new Spark plugs and then drive it hard for 45 minutes. This will ensure that your Cat is working and you will pass.
        • mr.vang
          • 4371
          if your car is running great with no issue, 90% is a bad cat. try cleaning your cat, link below
          • ScottyB326
            • Aug 2011
            • 175
            Don't assume it's a bad cat if it's not gonna pass. And if you can pass with a brand new cat the problem is still there.
            Failing NOx emissions indicates high cylinder temperature, which can be from a lean mixture, high compression, even faulty coolant temp sensors and stuff, etc. Also a bad EGR valve can be culprit.
            New BMW's don't even use EGR's tho, they just have super burly cats that clean everything out cuz BMW thinks EGR valves rob performance.
            • carfantiti
              • 790
              go buy the pass smog bottle crap you put in your gas tank .I always do just incase and have car hot I pass with flying colors worth a try.
