Sunday night while i was driving in town car just shut off. It wouldn't start back up. Since then have been checking things out. Fuel pump is good, replaced sparks plugs, replaced coil, i'm getting spark. Still nothing, i just got a crank sensor in and will replace it tomorrow but, if that doesn't work then i don't know what else it could be. Anyone have any tips, this happen to anyone else before? Thanks
Car died...need help
Not yet, busy at work today.
Was thinking that also. Would it be possible to swap it from another e30 just to test it out? How much of a pain in the a$$ is that?Comment
ECU's can be swaped in like 5 minutes, it's easier then changing your wheels. Crank it over for like 10 seconds then pull a plug and see if there's fuel on it. Just because your pumps good doesn't mean the filter is or the injector coils are opening. Give it a try hope it helps.Comment
swapped ecu's with my boss' e30 and still nothing. The plugs have on them. Now my guy said there seems to be low spark.ECU's can be swaped in like 5 minutes, it's easier then changing your wheels. Crank it over for like 10 seconds then pull a plug and see if there's fuel on it. Just because your pumps good doesn't mean the filter is or the injector coils are opening. Give it a try hope it helps.Comment
the fuck? if the cam isn't spinning then you have no timing belt...im not sure if that's what you mean, or is it?
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
1989 325i - Project/weekend driverOriginally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - ToyComment
hopefully tomorrow we will be able to take it apart and look at the belt itself. I have heard couple of cars with blown timing belts, and even searched for videos of e30's with blown belts, and they all sound the same while trying to crank. Mine doesn't sound like that, sounds normal when it's cranking.Comment
