Found an elusive 7 bearing SETA head.
  • ForcedFirebird
    • Feb 2007
    • 8300
    I picked up a SETA motor a while back, pulled the head and measure the stroke to be sure. The PO told me it had the "885 head swap" but never opened the valve cover before taking it to the shop. Well, a customer's car is here (same guy I got the motor from), pulled the head on his car to add studs and MLS gasket, but found a crack on the head from the seat to the coolant passage - SO - I take the "885 i head" apart and noticed it had an "m" stamped on it. SETA cam, but it's weird, I see on the forums all the time that there was no 7 bearing SETA cam, but thing sure has 7 journals, single springs and "M" cam.
    Anyone have a link to get the specs from this cam? It's easy to get the lift by subtracting the base circle from max lobe, but the duration looks really short at peak lift.
    john@m20guru.com
    Links:
  • Myster-E
    Performance
    • 552
    I told you so!
    1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
    Visit www.BimmerHeads.com for all of your 12 valve needs!
    • ForcedFirebird
      • Feb 2007
      • 8300
      Originally posted by Myster-e
      I told you so!
      You did?
      4 and 7 nearing cams exist, but what's the norm?
      john@m20guru.com
      Links:
        • 37832
        I think I told you so actually. Myster-e is a friend of mine though.
        All of the Super Eta engines I have seen have been the 7 bearing.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Wh33lhop
          • 11705
          All of them are 7 bearing. ;) IIRC only the 200 casting heads are 4.
          paint sucks
          • whodwho
            • Jun 2008
            • 1547
            Let see if this will help settle this, there are 4 journal ones as well. There have been many of posts of people wanting to change out the cams and needing to drill the oil holes.
            I can take better pics when I do my next valve adjustment, this is just a pic from when I had it off. You can see by the ports and part# that it is a 885, you can see by the bottom arrows there are journals not drilled, and you can sort of see by the top arrows that the cam doesn't have a journal there.
            If you save the pic local I think you can see it bigger
            My M20 Frankenbuild(s)
            4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
            • TrippinBimmer
              • Feb 2011
              • 182
              Nothing usual. I posted up my 7 Cam Bearing and 4 Cam Bearing SETA Cam...
