M20 headbolts, no washer.
  • AutoXinE30
    • Aug 2007
    • 277
    I ordered a set of headbolts and they came with no washers, are the washers neccesary? Are the old ones reusable?
  • CHIF8008
    • 3447
    i reused my washers without any problems
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
    • ttrousdell
      • Nov 2009
      • 1770
      they are reusable. I recommend using them so you don't dig into the head when you torque the bolts down.
      The Build:
      • AutoXinE30
        • Aug 2007
        • 277
        Good times. Thanks.
        • riceh8r
          • Dec 2010
          • 133
          dont believe you will ever get accurate torque without them.
          • Ceeker
            • Sep 2009
            • 2821
            as mentioned above they are necessary; I had a incident where I got a car with a leaking head gasket. The head was bolted down without washers and suspect that "if" it was torqued properly which I doubt it was resulted in the bolts digging into the bolt hole surface of the head and causing the torq specs to be off later resulting in a leak.
            • ROLLingKING
              • Apr 2011
              • 1169
              are the valve cover nuts supposed to have washers? its a good point how torque specs will be thrown off if washers are missing
              m20 is plenty. im simply a drifter.
              build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
