race gas?
  • EThirty318i
    • Dec 2010
    • 219
    race gas?
    This weekend I'm going to participate in my 2nd autoX event.
    My brother mentioned buying a tank of race gas. My concern is, would this hurt my stock fuel system/ management? I have the 173ecu w/ TMS 93 Octane chip.
    are there any pros and cons?
  • Myster-E
    Performance
    • 552
    Higher octane means more power. I would
    1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
    Visit www.BimmerHeads.com for all of your 12 valve needs!
      • 34844
      no, no, no it doesn't.
      run the octane rating for your compression ratio and timing curve. the stock engine is only 8.8:1. the stock tune is way, way below MBT. using race gas is going to be a total waste of time. and since it burns much slower, it's going to likely cost you power too.
      Even with a chip, it's not going to be helpful. stock M20s are not knock limited.
      • _r2h
        • Jun 2011
        • 41
        Only if you run compression and/or timing to make use of said higher octane to create higher power.
        Octane is just a measure of detonation resistance of a particular fuel.
        :D
        '87 325i
