ETA tdc
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    ETA tdc
    i searched and i can't find a photo of eta tdc, it appears on the bottom end its the same but the top end im not so sure about so does anyone have photos of that?
    also found a broken head bolt :/ thinking about just buying a whole nother m20 :/ shitty.
  • davem
    • Jun 2010
    • 705
    You know there's an m20 section right? noob...
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      i put this in the general because i'd like it to be answered soon since i have a friend over and were just about to pull the head.....
      i understand putting things in there subsection but when you need an answer quick i don't think there's anything wrong with posting it in general.
      • nebulous123
        • Jun 2011
        • 923
        tdc is when the crank pulley is matched with its notch and the cam gear is matched with its notch. if only the crank matches and not the cam then keep cranking till both match up.
        BTW i literally typed m20 tdc into google and pulled those images off the first page result.
        '84 325e - "Elizabeth"
        '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7283
          mine don't look the same on the top end, i do not have any indication on that area, there is an arrow on the inside of the crankshaft hub, but nothing to match it to....
          • mkcman17
            • Jul 2010
            • 8240
            if you're missing the lower timing cover it will prove very difficult.
            also, crank turns twice the cam...just keep that in mind.
            1989 LN106 Hilux / 3.0TD SFA
            1974 2002tii / stock
            2002 IS300 / 5spd LSD
              • 37829
              We have sections for a reason. You're not an exception to anything.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • BoxDriver86
                • Jul 2009
                • 912
                To answer your question (now that it's posted in the right subforum) the timing mark is on the back of the cam gear in some etas. I had the same concern when I did my TB the first time.
                You'll see the arrow at the front, but it correlates to a small indentation on the back of the gear.
                Hope that helps.
                • Rigmaster
                  • 3464
                  top end = camshaft
                  bottom end = crankshaft
                  So, which one are you having trouble with?
                  They (m20's) are all about the same. Even with the crank pulley off, you should still be able to line things up with no problem- there's a V-notch in the nose of the crank that should line up with the mark.
                  • Pantless Spency
                    It's McRib time!!!
                    • Feb 2011
                    • 7283
                    my bad, i accidently called the cam the crank lol.
                    i got it all figured out, thanks guys.
