What oil do YOU use?
  • dnguyen1963
    • Nov 2011
    • 2651
    #61
    Originally posted by 603Racing
    On page 3 of this thread I posted a link to research done by LN Engineering on engine oils. It will answer your question on zinc. The very very short answer is, higher levels of zinc are better for motors designed 30 years ago. But there's more to it than that.
    I order my oil from Autowerks of America. They have a website but they don't have oil/fluids listed on the site. It's easiest to call 1-888-4awerks to order it.
    Ok, so it is not the zinc, but the zinc:detergent complex that offers anti-wear properties. These detergents needed to have counter ions and Ca2+, Mg2+ did not work well. Calcium and magnesium tend to form oxide crystals which can be really bad for an engine. The article did not provide any specific data on wear. I would be interested to see actual comparison between oil with and without zinc:detergent additive. How much more wear can one observe or measure without the use of additive? Is this a marketing scam to get us buying more expensive oil for a miniscule improvement in wear? I can see that race car drivers can benefit from the use of expensive oil, but for average drivers are we wasting money?
      • 34847
      #62
      we have camshafts with metal on metal contact. That's not just marketing BS - it needs protection.
      • Eric
        • 5142
        #63
        I run joe gibed gt5 in my euro S50. Its good up to 280f and I regularly see 260f.
        In the e28 M5 I use Bmw bottled castrol 5w30.
        • dnguyen1963
          • Nov 2011
          • 2651
          #64
          Yeah, but at ppm level? One thousand parts of zinc:detergent in a million parts of oil. It is hard to believe. There is oil lubricating the camshaft, right?
            • 34847
            #65
            generally it seems that ~1100-1300 or so is a good guideline
            you're kidding yourself if you think a 5w30 oil is going to adequately protect the camshaft, for example. Or a low- ZDDP formula 10w40 even. the weight of the oil doesn't matter much to the cam since it doesn't develop an oil film like the crank bearings do. the volume of oil makes no difference - the camshaft and rockers are under extreme pressure. the only thing protecting them is ZDDP.
            metal on metal..
            • dnguyen1963
              • Nov 2011
              • 2651
              #66
              metal on metal..
              I never race my car and for the last 13 yrs I have put 5w30 in the engine...have not seen any problem. Knock on wood. What would you recommend to use when the temp is below zero? I drive my car year round and found that 5w30 works the best when the temp is that cold. Summer is not that hot up here either.
              • 603Racing
                • Dec 2010
                • 612
                #67
                I'm not trying to sell Brad Penn, just providing my opinion and some of the information I used to come to that opinion. My specific opinion is use the oil that was designed for the engine at the time the engine was designed, they were made to work together. Newer is not always better.
                Everyone has their own experiences and preferences. My experience is racing a stock M30 motor that had 92,000 miles on it when I started racing with it. Now the motor has just over 95,000 miles on it. 3,000 plus miles of racing, only racing. It has just recently started using more than 1 quart of oil for every 8 to 10 hours on track. It's a testement to the motor for sure, but I have to believe the oil had something to do with that.
                I also subscribe to the school of thought that race engineering leads to better engineering for the masses. So I plan on using Brad Penn in my e30. Yeah, it's more expensive, but to me it's more than worth the few dollars difference. My dad runs Penzoil 10/40 in his Dodge, it has over 200,000 miles and only uses two quarts every 3,000 miles. Wouldn't be my first choice, but it works great for him. In the end, a lot of oils are the same, weight may not make a big difference, and to each their own. +1 for Z and P! :)
                90 325i DD/Track
                03 Durango 5.9
                Originally posted by e30mpg
                It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  #68
                  2 qts every 3000 miles! That 's an awful lot of oil. I hope his engine can hold more than 4- 5 qts of oil. Mine does not burn any oil at all or very little...for a 23 yrs old car.
                  • DrLeadFoot
                    • Aug 2011
                    • 461
                    #69
                    Brad Penn! It's green and American!
                    Instagram: @DrLeadFoot
                    • lateracer
                      • Sep 2009
                      • 302
                      #70
                      Nah, that's not a lot of oil for racing a motor like that. All things considered, it's actually pretty good. Sounds like what most of us see under track conditions with old motors.
                      If you look here, you'll see it's not just BMW's that burn this much.
                      • HarukoE30
                        • Nov 2011
                        • 1057
                        #71
                        Once I get my Engine dropped; I'll give this Brad Penn 20-50w a shot & try to keep an eye on my findings. E30 325i
                        Edit: I actually ended up running with Kendall GT-1 20w-50 No issues thus far.
                        Originally posted by James Crivellone
                        1) The internet is NOT serious business.
                        • illest318i
                          • 1472
                          #72
                          What's good for an M10 motor and a good brand you guys recommend..
                          IG: @_j.wn
                          • HR2L
                            • 724
                            #73
                            Originally posted by MR 325
                            20w50 is the BMW recommended weight for the M20 engine, period.
                            I run Valvoline VR1 in the turbo car and Cheapo anything in the S50. :)
                            This! VR-1 or Brad Penn 20w50 are great options. If I am desperate I will run Castrol High Mileage 20w50.
                            Brad Penn 10w40 partial syn would be perfect for california all year round weather. I'm assuming this is an m10 1.8L k-jetronic out of 320i?
                            • illest318i
                              • 1472
                              #74
                              Ughh actually it's a 318i
                              IG: @_j.wn
                              • ray325e
                                • 252
                                #75
                                castrol 15w-40
                                LoveOfMyLife<3
                                85 325e ...
