On a few different occasions I have noticed a few drop of oil leaking from a few of the bolts on my oil pan, tightened em up problem goes away, but comes back like a week later.. what do I need to do? Reseal my oil pan?? Its an 86 325e.
Also I have a small (a drop or two) coming from my transmission where on the seam below where the star looking bolt is. Did some tightening... same prob. Does it need to be re sealed or something? And would a quick fix like jb weld where that drop once a week comes from, be a bad idea?
Finally tranny fluid. The haynes manual specifies [COLOR=blue !important][COLOR=blue ! important]gear[/COLOR][/COLOR] oil, but looking through forums there doesn't seem to be a [COLOR=blue !important][COLOR=blue !important]common[/COLOR][/COLOR] consensus and my haynes manual is for like 10 models, so its somewhat shotty as to what methods go to which model.. should I just use the 80 gear oil it says???
