I am sure this has been covered before, but I am having issues trying to find someone who has done a similar job before like this.
I have an 87 325i vert that i "think" has a slight rod knock. The valves clatter loudly even after I adjusted them, and there is minor sludge build up in the head. I have a friend who has a b25 lower end that came out of his track car that the timing belt snapped on. He is selling it to me for $50. He says it spins freely and wasn't damaged when the belt snapped. I was thinking about sourcing a used head from pick n pull out of a wrecked 325i and having it checked. I should be able to get all the parts, ie short block, head, timing belt, water pump, and gasket kit for around $200-$250 and put it all together myself. I am curious though.....the short block still has the cross hatching in the cylinders and none of them are scored. It has been in his storage shed for a few months. I am wanting to know if I tear it down to have the block hot tanked, can I re-use the crank and bearings as long as they aren't damaged? Installing new main and rod bearings is kind of intimidating to me and if there aren't any issues with the engine visually when I tear it down, should I theoretically be able to reuse everything?
