can i put an I head on my non super eta without modifying the pistons or head?
  • richardkeith97
    • 1693
    cracked a head on my 85 eta. can i put an I head on it? i know you can just slap one on a seta without any modification of the pistons or the head. is it the same for a regular eta? thanks for the help.
  • Ceeker
    • Sep 2009
    • 2821
    I would recommend getting the I - intake manifold as well. the blocks are the same for both eta and seta. it is called Seta because of the upgrade.
      • 37833
      Yes, it will bolt on and work. You want to also swap the i intake, wiring, computer, injectors, AFM, o2 to go with it.
      Can you please stop spreading your "advice"?
      The Super Eta was an 88 only engine option, it has different pistons than the Eta or i engines.
      Grover Beach, California
      BimmerHeads.com
      • richardkeith97
        • 1693
        awesome thanks. i know all about the 327i and how to do it just never seen it done with something other then a seta block. thanks for the help.
          • 37833
          Good friend of mine did it on his Eta. He also did a port/polished head with cam. It was faster than a stock i.
          BimmerHeads.com
          • Cabriolet
            • 9620
            you will end up with sh*t compression without changing the piston heads, or turbo'ing.
            my friend had his build at dinan. he had an eta block and crank. using I rods, since the eta's are a bit weak. swapped out the intake manifold, exhaust, DME. he had custom piston heads made and had the head ported/polished and 272 cam.
            Much wow
            I hate 4 doors
              • 37833
              They're called PISTONS. Not piston heads.
              You're comparing custom pistons and different rods to a stock Eta bottom end. Apples to oranges. Also, whoever told you that the Eta rods are "weak" is an absolute fucking idiot.
              BimmerHeads.com
              • Cabriolet
                • 9620
                seen snapped ones with my own eyes. 200+hp@7k pow
                plus they are heavier and thus rob the engine of power.
                Much wow
                I hate 4 doors
                • Simontibbett
                  • 127
                  He did all of that WITHOUT swapping pistons and had it faster than an I?
                  I thought you pretty much HAD to swap pistons or else it'd be slower than a stock E because of the low compression?
                  www.simontibbett.com
                  • Ceeker
                    • Sep 2009
                    • 2821
                    I don't understand what your point is. I didn't say anything contrary to your statement. I said it will bolt on...perhaps my statement wasn't clear. I didn't mention internals only block. I think everyone is really saying the same thing. sorry..
                    • accident
                      • 7303
                      You also said that the two bottom ends were the same, which is not true. The SETA had different pistons and rods.
                      Moral of this story?
                      • M-technik-3
                        • 18946
                        This thread ______ is going wonderful.
                        • mr.vang
                          • 4371
                          "your wrong and i'm right thread"
                            • 34847
                            heavier? they weigh almost exactly the same amount. how do they rob it of power?
                            my eta crank seems to do ok at 7.5k..
                            • Stephen
                              Шлем ишака
                              • 10774
                              My brain hurts.
                              The basic 2.7i setup will not "snap" and is a huge improvement over an eta.
