oil flow diagram?
  • TobyB
    • 5266
    oil flow diagram?
    I would swear I've seen an M20 oil flow diagram (for the 25 with an oil cooler)
    but I can't find one with the Googles.
    Any help?
    thx
    t
    I think I have seen an oil flow diagram in the TIS. If you are curious as to how the oil cooler works, I can tell you that.
    Oil from the pump comes up to the oil filter adapter. Depending on engine temperature oil then goes through the filter and on to the engine or through the cooler then through the filter and on to the engine.
    • TobyB
      • 5266
      Nope, I'm cool with the cooler-
      thanks, tho-
      I'm trying to figure the cleanest way to plumb an accusump...
      t
      • Thing90
        • Jan 2020
        • 1
        thanks, tho-
        t
        Hallo.
        did you find flow direction on the oil cooler? I am also installing a accusump on my M20 filter console
        • TobyB
          • 5266
          I didn't- I just run a baffle and a crank scraper, and it holds pressure well enough...
          I did find a diagram, tho- I'll dig around...
          t
