Hesitating? Feels like fuel is cutting out?
 Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot you
 Bumping this back up it happened again! So here's what I have done to try and fix it.
 New fuel filter
 New Bosch +4 plugs
 Swapped main relay (can someone elaborate why this could be a cause)Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youComment
 I just cleaned them. I'll buy a new set and see how it goesOriginally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youComment
 This is weird Im having the same problem too. Just bumped my thread on it today. So far iv changed the spark plugs/wires cleaned the cap and rotor changed the fuel filter and changed out the cps and I'm still having problems. But the only difference is mine won't let the car go past 3 grand or it will choke out and stall and It wot idle till the next day
 I was going to go for the fuel pump but I'm having problems getting it out the tank. Any help?
 :edit: I got it out. Cleaned it and put it back in but it didnt seem to make a difference.'89 Delphin 2.8 Cabrio
 '94 Yamaha FZR 600
  Originally posted by FlexdXJIs that thing on air? Originally posted by FlexdXJIs that thing on air?Comment
 check your air filter it may be dirty causing hesitation during top end but still allow enough air to cruise normally.Comment
 Nah I tried it without the filter attached to see if the arm is responding goo and it was acting fine.'89 Delphin 2.8 Cabrio
 '94 Yamaha FZR 600
 Sounds like a misfire. I had that happen too. Got a new coil and fixed itThis is weird Im having the same problem too. Just bumped my thread on it today. So far iv changed the spark plugs/wires cleaned the cap and rotor changed the fuel filter and changed out the cps and I'm still having problems. But the only difference is mine won't let the car go past 3 grand or it will choke out and stall and It wot idle till the next day
 What's wrong with these plugs?Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youComment
 The main relay is a remote possibility, only because it supplies power to the fuel pump relay. If the main relay were to be bad, the tach would go to zero when the engine lost power because the DME would loose power.
 A bad fuel pump relay, bad fuel pump or FPR, bad engine harness, or bad bad DME are all possibilities at this point. If you see the econometer drive towards zero when the engine looses power the DME probably isn't the cause since that indicates that the DME realizes that insufficient fuel is being delivered and tries to increase flow.
 The first diagnostic should be to tee a pressure gauge into the the fuel rail supply line and zip it to a windshield wiper so you can see what fuel pressure does in an event.The car makes it possible, but the driver makes it happen.
 Jim Levie, Huntsville, ALComment
 Thanks for the info man. If I test fuel pressure from the FPR and it checks out to be good can I cross the FPR off the list of possible causes? I swapped DME's one with a dinan chip now and still had the problem. So I'll try out what you told me thanks bro!Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youComment
 Had similar intermittant issues with mine. Ended up being a bad plug wire. The wires looked great but as the RPM got higher and the engine was under load, it would randomly do it. Try getting some wires to swap from a parts car.Comment
 It seems like there are so many possibilities for the same set of symptoms. It turns out mine was just a dirty afm and after cleaning it with cleaner it ran better. Still stutters but only once in a while. I will continue to clean it and if it doesn't work I will buy a new afm. Or just drop a s85 in. Havnt picked yet...'89 Delphin 2.8 Cabrio
 '94 Yamaha FZR 600
