Hesitating? Feels like fuel is cutting out?
  • Killacortes
    • 1937
    I was driving on the highway and my car hesitated real hard and the tach started going down slowly. So I put it in neutral and coasted for a bit and then it seemed to run fine again. It's happened a few times, seems like fuel is cutting out. Could this be a fuel pump problem? Or a bad FPR?
    r3v does not fuck around. First you get banned, then they shoot you
  • E30_fiend
    • Apr 2006
    • 7348
    could be a fuel problem for sure. change the fuel filter to start
    Taylor
    • Killacortes
      • 1937
      Changed it today and still hesitated once I was on the highway. Should I do FPR next?
      • E30_fiend
        • Apr 2006
        • 7348
        Swap your main relay out with a known good one.
        Pretty sure that will solve your problem
        Taylor
        • delatlanta1281
          Dart Master
          • Mar 2006
          • 10317
          It could be a number of things. Check the main relay as stated above, then check your coil to see if it is in good working/ physical order, check your main ground as well.
          Yours truly,
          Rich
          you kids get off my lawn.....
          • Killacortes
            • 1937
            I will buy a new main relay tomorow and see how that goes. I had a problem with the coil before so I bought a new one. Is the main ground the one that goes from the block to the body? Thanks for the info guys
            • Killacortes
              • 1937
              Also I read it could be a dirty c101 plug? Is this right?
              • Gizmo
                • 53
                I'm having the same problem (-_-) I'm checking my FPR and Fuel Pump this weekend. Does yours do it while you're driving in the street as well?
                BAZINGA!!!
                • kronus
                  • Apr 2008
                  • 13032
                  it could be your fuel pump starting to go. Have you run the fuel very low recently? That tends to stir up sediment and clog stuff...
                  cars beep boop
                  • Killacortes
                    • 1937
                    I usually get gas before the light turns on. So I dont think I run it down that low. It doesn't do it very often maybe once a day if that. I think it's mostly when I drive it pretty hard lol.
                    • 1fastETA
                      • Apr 2011
                      • 264
                      Positioning sensor..
                      • Killacortes
                        • 1937
                        CPS is brand new. Like 2 months old.
                        • 1fastETA
                          • Apr 2011
                          • 264
                          Fuel relay?? Or fusible link?! Bad external pump (if it has one). Fuel filter of any kind?! Dirty injectors, fuel rail! Fuel pressure regulators. Like listed above main relay. Grounds?!
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5274
                            Take a look at your plugs. This happened to me and they were fouled.
                            Originally posted by priapism
                            Originally posted by shameson
                            • ghalee30
                              • Jul 2011
                              • 614
                              does the car jerk a little after it catches. check your plugs, cap and rotor.. chances are your rotor is shaved down and isnt catching a good spark on the cap.
