Pulling a Crank Shaft pulley
  • WUGcatsvt
    • Nov 2011
    • 38
    I was reading the torque specs for the crank shaft pulley. The Torque specs are something like 350 Ft Pounds. That is a crap load of Ft Pounds. My Torque wretch only goes to 150 Ft pounds.
    I am trying to get some advice on pulling it? Also re-installing it. Is there any trick to this? Has anyone done an estimation of the 350 Ft pounds using a bracker bar? Also does anyone have some tips on keeping the Crank from moving?
    Thanks for your help
    Dan
    2002 SVT Focus for track and DD.
    1986 BMW 325E also for track and DD.
  • paperplane94
    • Jul 2011
    • 420
    I believe there is a tool that you can use.
    I also heard that you can use the torque multiplication of the starter motor.
    Sorta like this:
    • paperplane94
      • Jul 2011
      • 420
      You should also use red loctite on the bolt when tightening if you can't reach the 350 ft-lb of torque.
        • 37828
        Tighten it with a good 1/2" impact gun on full strength. Trust me, it's plenty.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • ttrousdell
          • Nov 2009
          • 1770
          get an 8ft. cheater bar or something to remove the "jesus nut". Block one of the pistons with a block of wood thats being heald down by a peice of flat stock bolted to the block with the head bolts.
          The Build:
          • WUGcatsvt
            • Nov 2011
            • 38
            Thanks for all the help. I may see if my impact gun can handle it but It is only rated to 300 ft lbs so I doubt it. It will be a challenge but it will come off.
              A good way of getting that sort of torque is to use your body weight. Figure out how much of a lever arm is needed for your weight. Put a foot on the breaker bar/extension at that point and put your full weight on the bar.
              • Ceeker
                • Sep 2009
                • 2821
                I removed and installed mine with my compressor bumped to 120psi and sat on it with the gun for about 30 sec before it started to give.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Definitely use Loctite, but you need the bolt that tight regardless...
                  ...because I have seen them work loose when people try doing this ^
                  I made a tool to hold the crank hub. Used the pulley to mark a piece of flat aluminum, drilled the holes out and cut a handle on the end of it. Just used it yesterday on an s52 (will work on all the 6's).
                  john@m20guru.com
                  Links:
                    Do not use Locktite on the crank pulley. It will be pure hell trying to get it off later. Do tighten it to 325-350ft-lb as the manual calls for. An impact wrench just doesn't get it as you have no idea how tight that is.
                      • 37828
                      Well, I haven't!
                      I am getting tired of people acting like I am fucking clueless around here.
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • paperplane94
                        • Jul 2011
                        • 420
                        Well, I haven't!
                        People just have different opinions that's all. Your knowledgeable but others didn't have the same experiences.
                        OP you might wanna read this, only if your hardcore:
                        http://www.angelfire.com/blues2/bimm...crankbolt.html
                        • Ceeker
                          • Sep 2009
                          • 2821
                          Well, I haven't!
                          on the contrary; I've read your posts and think you are very knowledgeable, so it goes without saying. :-) I like the head work you guys are doing too!
                          I think people can learn lots on here from the established members.
                          and no, I'm not saying this just to kiss your ass, ok?
                          • KenC
                            King of Kegstands
                            • 14396
                            Just put the ebrake on and put it in 5th gear. That'll hold the crank.
                            Originally posted by Gruelius
                            • WUGcatsvt
                              • Nov 2011
                              • 38
                              That is a pretty neat Idea. The car is not in running shape yet though. I am crafting a tool right now to hold the crank steady.
