To start, my engine has been running strong and great. No problem starting up within 2 seconds, not running rough, no problem idling, no smoke or anything; it was perfect. Since it's been about 5 years since it was last changed, I decided it was time to change the timing belt.
This is the first time I've undertaken this, so I made sure to pull up a couple different guides. I spent about an hour making sure the camshaft and crankshaft were both aligned with one another.
Now when I start it up, it takes about 5-10 seconds, if I don't hold the gas pedal down, it'll go to ~1500 RPM like any car when it's initially started up, but it slowly dips down until it dies while in neutral, there is white smoke coming from the exhaust, and it runs really rough.
