I read through a bunch of no start threads and couldn't find a similar problem so here goes.
About every 5th start, I'll turn the key, hear the starter solenoid click, and then nothing happens. If I get a jump it starts immediately. I can also push start the car just fine.
I have 2 *new* main relays, and sometimes swapping these in an out will allow it start, sometimes not. I always have 11.9V at the main relay's pin 30 when the key is in the ON position.
Battery and starter are 14 months old. I checked the continuity across the fusible link and it is fine.
The only other thing I can think of is the ignition switch, but I don't know why swapping relays around would help. Any thoughts?
