The fact that the solenoid clicks implies that system voltage is getting there right?
I found the starting schematic in Bentley and it looks like the problem must be a faulty solenoid switch or if system power is getting to the starter via the field winding strap, then something internal to the starter is bad. Since they are sold as one unit, I must just need to replace it.
The only other thing is that I don't believe I have the load reduction relay hooked up. I just have alternator and battery cables on one post and the c101 black/yellow wire on the other post
My car is an 86 with motronic 1.3 conversion, and the late model (smaller) starter. Even though my fuse box has all of the relays populated, according to Bently only 1988+ came with load reduction.
Anyway, could load reduction play a role in this problem?
