when my engine in cold, maybe for the first 2-3 minutes, I hear a screachy belt noise at 2-4k-ish rpm. No noise at idle.
I have alread removed the drive belt and ran the engine while cold to verify that it was in the timing
I've have that problem before, replaced the t-belt and tensioner and water pump with new OEM parts (from Blunt) and the noise went away for 6 months or so. Now its back...
I don't believe that a new tensioner bearing went bad that fast, but it is possable. Is it possable I mis-adjusted it? There is a tiny oil seepage from the intermediate shaft seal, will a drop of oil do that?
