CPS Question! Car wont start!
  • Cody Vent
    • Nov 2011
    • 51
    My 89 325i died suddenly on the freeway with no stutter or hesitation. I tried the fuel and main relays, and replaced the CPS with no luck. I can smell fuel when cranking, not super strong but I can smell it. I do not hear the fuel pump priming though im not sure if I should be able to or not.
    My question about the CPS is that the new CPS I got, the plug end is not the same as the one that i replaced it with. it fits in the connector but the wire comes out of the opposite side of the plug then the original. Could this be a problem???
  • Sagaris
    • Sep 2009
    • 2243
    This may be obvious, but did you make sure you didnt mix up the crank position sensor plug with the other one that goes to the spark plug impulse sensor?
    • Cody Vent
      • Nov 2011
      • 51
      I did actually, but caught that I had done so,then corrected it :p But still nothing
      • Cody Vent
        • Nov 2011
        • 51
        Because I did noticed the impulse sensor plug is exactly the same as my new CPS, so that is how i plugged the wrong one in
        • paperplane94
          • Jul 2011
          • 420
          Look in your oil filler hole, is the cam turning? As in, broken Timing belt?
          • blocke
            • 1305
            Do you have spark?
            Parts Wanted
            The Never-ending Resto Mod
              • 37833
              Originally posted by blocke
              Do you have spark?
              These would be my two suggestions/questions as well.
              Grover Beach, California
              BimmerHeads.com
              • TurboJake
                • 3780
                T-belt....
                Leave Me Transaction Feedback
                • Ian Bowers
                  • Apr 2008
                  • 1120
                  Check fuel pump fuse?
                  • 5Toes
                    • 9836
                    I did that once :)
                    quick call to Luke Fisher and I felt like a tard
