What to do with 300k miles?
  • 1987_325is
    • Jun 2010
    • 106
    Recently picked up a 88' 325 with 306,000 miles. I want to build an m20, I have been pricing out a 2.7 build including new main and rod bearings, double valve springs, new valve seals, a pretty aggressive cam (possibly cat cams 285/285), new rockers, I intake manifold, throttle body, fuel rail, ecu, top and bottom end gasket kit, timing belt and tensioner, port and polish on the head and intake manifold.
    However the only weak point I can see with this set up is reusing a block/rotating assembly with 306,000 miles, I figured I would do a compression test before I pull everything apart and see what kind of numbers I get.
    What numbers should I expect to see if I do a compression test?
    Also would it be worth it to source a less mileage 'e' block, get some custom pistons, 524td crank, etc?
  • VRSTLE
    • Dec 2010
    • 146
    I just tested the compression on my m20b25 that has 250k miles on it with a broken odo and the highest number I got was 131psi and the lowest was 119psi I have been told that it is acceptable as long as the lowest number is no less than 85 percent of the highest number for example my highest was 131psi so my acceptable range is 131-111
    • 1987_325is
      • Jun 2010
      • 106
      Hey thanks for the good info, helps a lot, I will post the results when I do the test.
        A 300k block almost certainly will beed a rebore and new pistons. The crank probably only needs polishing, but measurement of the crank journals will tell.
        • 1987_325is
          • Jun 2010
          • 106
          That is what I have been worried about, however in this case I would probably bore to 86mm, custom pistons, low mileage 524td crank, then hopefully find a cheap low mileage 'i' head, cam it, and port and polish. Just not trying to pour thousands into an m20 lol.
          • 5KWattson
            • Apr 2009
            • 809
            24v swap it for more power, less money, less down time of the car
            "God created turbo lag to give V8's a chance" Taylor D.
            • downforce22
              • Aug 2009
              • 3193
              look into the castrol 1 million mile test on youtube. They drove an e30 1,000,000 miles and it still had the factory cross hatching. Of course that did not take into account idling, cold starts, overheats, bad maintenance etc but it is a testament to the strength of the m20.
              • 5KWattson
                • Apr 2009
                • 809
                thought that was the mobil1 E30
                  Rebore, crank, pistons, & rods will have you at, or above, a thousand. The head is where all the magic happens and a full rebuild of a used head (and a cam) is another thou. A lower mileage M20B25 engine is going to produce almost as much power as what you contemplate and be a whole lot less expensive. An M50 swap will be about equal and cost no more.
                  • 1987_325is
                    • Jun 2010
                    • 106
                    That's an incredible video, I don't know how i haven't seen it before. Thanks for the heads up. Definitely makes me a little less worried.
                    I have 3 cars at the moment so I am not worried about down time to much lol, I also have enough parts laying around that I might be able to build about a 190 hp 2.7 spending under 1000. And I love building motors so would rather go this route.
                    • 1987_325is
                      • Jun 2010
                      • 106
                      Once I pull the motor apart I will know for sure where I am at. If the block is shot then I still have another eta block in decent shape that I would use the crank and rods out of, new main and rod bearings (300ish?), reuse the 88' seta pistons with new rings(idk how much), then I would plan on sourcing a low mileage 'i' head (400 max), add timing belt kit, gasket kit seals and all (300 max) and I'm looking at a grand, I can probably source parts for slightly cheaper. I haven't gathered exact values yet.
                      • 1987_325is
                        • Jun 2010
                        • 106
                        Anyone happen to know the best place to get quality oem engine parts? BMAparts seems like they have the best prices, just wondering if there is anywhere better. Thanks.
                        • BoxDriver86
                          • Jul 2009
                          • 912
                          I have found no better than www.blunttech.com especially when it comes to prices.
