stuck cam
  • VRSTLE
    • Dec 2010
    • 146
    stuck cam
    so i took my head to a machine shop and they got all of the valves out of sync so that they would all be flush with the bottom of the head
    i have gotten the head back and i can not get the cam to move at all. is it possible that they some how wedged one of the rockers against the cam to the point i cant spin the head at all.... tips on what to do. and i cant just pull harder, i already tried to move it with a pipe wrench
  • Myster-E
    Performance
    • 552
    Have you tried turning the cam with the cam gear on it?
    1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
    Visit www.BimmerHeads.com for all of your 12 valve needs!
    • VRSTLE
      • Dec 2010
      • 146
      The torx bolt started to unbolt
      • Sagaris
        • Sep 2009
        • 2243
        EDIT: I am wrong, BUT on cars with camshaft bearing caps, this is common when the bearing caps are not installed in the same orientation and location as they were removed from.
        • SpecM
          • Oct 2005
          • 4531
          Originally posted by Sagaris
          You installed the camshaft bearing caps on wrong.
          The camshaft bearing surface is line-bored so the bearing caps must be installed in the same orientation and location as they were removed.
          really dude?
          go look at an m20 head
          1989 cirrisblau-metallic 325i
          • IRON-E
            • 16548
            Could it be, that maybe you dropped a rock in the head?
            Sorry I had to.
            @IRON-E30 aka Edwin:D
            • andrewm
              • 456
              Take some pictures and post it.
              You can turn your cam the other way, OR you can use your hand while applying some pressure to the torx bolt and easily rotate the cam counter-clockwise.
              1987 Delphin 325e Sedan - Natalie
              1990 325i 24v
              1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
              • Sagaris
                • Sep 2009
                • 2243
                Originally posted by SpecM
                really dude?
                Okay, I am wrong.
                This is normally the case on cars with bearing caps though.
                  • 37832
                  Guess you should have done things the RIGHT way.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
