Need part # help
  • KEVORM
    • Jul 2011
    • 237
    Need part # help
    I need help finding the part number for #8 seen in this diagram
    http://realoem.com/bmw/showparts.do?...78&hg=11&fg=20
    All the bolts in mine sheared and rather than drill them out i just want to replace that piece. If anyone has one of these or knows where i can get one that would be great.
    84' 325i -> PRO3 #304
    Powered by Manntechnik
    Work in Progress Build Thread
    I'd get one from a salvage yard, but the way I read the IPB you should be able to use part 11. If you did the lookup on realoem by year/model, try using the last 7 of the VIN.
    It should be pretty easy to remove the broken bolts. Take the hub off and do the work in a mill with left hand twist drill bits. Pilot with a center drill so you can get a starter hole that is well centered.
    • Keith M
      • 2338
      I'll look tomorrow and see if I have an extra one Kevin.
        • 37834
        May I ask how this happened?
        Grover Beach, California
        BimmerHeads.com
        • Chuck C
          • 104
          The absence of part numbers for #8 and #10 indicates those parts are not available. Use #11 like Mr. Levie suggested.
          • KEVORM
            • Jul 2011
            • 237
            Well i went to loosen all those bolts a little at a time so i could just get them out using my fingers. I applied reasonable force, but not insane amounts (no breaker bar or anything), when i went to spin them out with my fingers everyone was broken off and only a few threads were left on the head part....my guess is that because the motor was in a car that was in a front end collision the bolts were compromised....or im really strong!
