2.5 head in a 2.7 on a 2.7 bottom end? lulz help me out guiz
  • digger
    • Nov 2005
    • 6196
    Originally posted by acolella76
    You will never get the '200' casting head to flow better than the '885' head. You will probably spend over a grand just to get it close. Also, you don't HAVE to swap the harness and stuff over to make the cylinder head work, but it would be pointless not to swap to motronic 1.3.
    I think you should go full motronic 1.3/885 head swap. It's not that expensive, and it's just like changing a head gasket. I can post a dyno graph of my 2.7i if that would sway your opinion.
    never is a long time........the thing is the stock 885 has much more flow potential than the rest of the system uses so you dont need a 200/731 to flow as much to make the same or more power.
    if i had to build a performance 2.5 i would start with the 200, it is a better shape to start with just on the small side which is fixable but you are right there is a fair bit of work and money involved,.
    • smooth
      • Apr 2005
      • 1940
      Originally posted by Pantless Spency
      a cam from pnp is like 30 bucks
      I believe Mr. 325 has head building experience so hopefully he'll jump in if I'm wrong, but I believe you need special tools to pull a cam or else you'll risk breaking it because it's hollow.
      So whatever else you decide to do, don't go yanking cams out of the PnP willy-nilly.
      Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
      • bastianshaw
        • Jan 2007
        • 2210
        also just to be clear this will lower your compresssion ratio right?
          • 37833
          This is totally true, you can open up the 200 head just as big or bigger than the 885 cylinder head. My buddy Myster-e is working on one right now for out project E30. We'll be drilling out the oil holes to run a reground i camshaft and opening it up to fit the bigger i valves as well. Once it's all done I'll post results. We're rebuilding an Eta bottom end for it to go on to. It's going to be a true 9:1 2.7i engine.
          If you break a cam while removing it you've got some serious issues. To remove the camshaft you'll need to pull the rocker clips, rocker shafts, and rocker arms.
          The 885 head on the Eta bottom end is roughly 8:1 compression whereas the Eta originally is 9:1 compression and the i engines are 8.8:1 compression. The 885 head swap on the Eta bottom end CAN make decent power though, it helps to have a port/polished head and a mild cam.
          Grover Beach, California
          BimmerHeads.com
          • camip
            • Nov 2011
            • 1253
            How much is this swap roughly with a port and polished head and cam?
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7283
              Lol I've already got my cam out. It's perfectly intact :)
              • acolella76
                • 2950
                Yup, it's the 24v cams that you have to worry about breaking. With these heads the spring isn't putting direct pressure on the cam while you pop bearing caps off. Instead it just slides out of the front of the head after you take the rockers and rocker shafts out.
                -Alex
