2.9 Stroker
  • jules325i
    • Jul 2011
    • 353
    2.9 Stroker
    So i'm nearly ready to start assembly.
    Seeing as i have the engine apart, i want to do as much as i can for the hp.
    I'm not sure what to do with the ECU, any suggestions there.
    I think ill leave my intake stock however would a big bore throttle body do anything.
    What i have.
    2.9
    10.5:1 compression.
    272 schrick cam.
    IE Rockers.
    Extractors.
    Ported and polished 885 head.
    329i
  • jules325i
    • Jul 2011
    • 353
    well
    329i
    • Killacortes
      • 1937
      Run mega squirt and tune it
      r3v does not fuck around. First you get banned, then they shoot you
      • Kershaw
        • 11822
        miller maf and psik.
        AWD > RWD
        • jules325i
          • Jul 2011
          • 353
          Now i know this is noobie but what is megasquirt is it injection and spark/piggy back ecu.
          329i
          • jules325i
            • Jul 2011
            • 353
            Yes i was reading up on the psik and they actually have dyno proven it which is surprising.
            I always though pod filters where a joke and you'd loose performance.
            Is the maf built into the psik's aluminium tube.
            329i
            • jules325i
              • Jul 2011
              • 353
              does anybody use this throttle body.
              Temukan keseruan di setiap game dengan mendaftar ID Anda di APG9! Bergabunglah sekarang dan rasakan momen-momen seru yang menanti Anda!
              329i
              • brody
                • Jul 2009
                • 334
                Yes, with The PSIK the MAF is integrated into the tube. I would suggest getting a WAR chip along with it because you are stroked and have other supporting mods. If that is too far out of your budget, the Stroker tuning package will get you a MAF, WAR Chip, Base tune and the remote tuning support.
                • jules325i
                  • Jul 2011
                  • 353
                  Does the war chip come with the psik, to tell the computer that a mac has been fitted. or is it just a plug and play.
                  329i
                  • brody
                    • Jul 2009
                    • 334
                    No the war chip is a separate product. The PSIK or our normal MAF conversions come with a traditional style chip with our programming. If you want/need the flexibility of adjusting our tune, the WAR chip will let you do that.
                    Remember, the WAR chip is just like other chips in the sense it carries the information your car needs to run. The difference is it is infinitely rewritable and allows you to use the same chip of the life and mod path of your car instead of always buying a new chip to account for each new mod.
