Steel Oil Pan Found
Steel Oil Pan Found
Originally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Tags: None -
I have a steel oil pan I found. not sure where it came from. looks like that but with a big dent. I assume it works and holds up to damage better -
1974.5 Jensen Healey : 2003 330i/5Comment
The oe steel oil pans don't have a provision for the oil level sensor like the e30 pans do.
2012 MCSCC/NSSCC CP class champ
HSAX InstructorComment
Oil lever sensor mounts from the top, not bottom.ส็็็็็็็็็็็็็็็็็็็็็็็็็Build Thread?Originally posted by blunttechI need you to exfoliate my ballsack
The hole in the bottom is for a oil level sensor, just not the e30 one.
could probably make it work, maybe cut/splice the e30 plug on? They look similar, but different part numbers.
I just picked up (for a bottle of Jack Daniels) what looks to be SuperETA engine (with only 80k) from an E28 that has the steel pan. The oil level sensor is quite obvious in the bottom of the pan and is different from an E30 sensor.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
so youd probably just end up banging the sensor and losing all your oil anyway?Originally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Comment
